MacOS M1 - Glitched Audio
Posted: 02 Jan 2024, 10:21
by Acornspreader69
Hello.
Ever since changing to M1 Monterey, I have this weird bug of Audio glitching when importing MPEG videos. Here are some specs and a video showing the glitched Audio.
Any help is welcome. Thanks
TVPaint Animation 11 Pro V 11.7.2 (11.7)
Model Name: MacBook Pro, Monterey Version 12.3 (21E230)
Model Identifier: MacBookPro18,3
Chip: Apple M1 Pro
Total Number of Cores: 10 (8 performance and 2 efficiency)
Memory: 16 GB
Video:
https://www.dropbox.com/scl/fi/cowsudbh ... m42ky&dl=0
Re: MacOS M1 - Glitched Audio
Posted: 04 Jan 2024, 12:32
by Acornspreader69
The Software also likes to crash after importing MPEG videos. Might have something to do with the FFmpeg code?
Posted: 04 Jan 2024, 13:16
by Thierry
We are aware of this, and are trying to find out why this is happening (I can also confirm that we can reproduce this on most of our Macs at the office).
As soon as I have more information I'll share it.
Best,
Posted: 04 Jan 2024, 14:15
by Acornspreader69
Hi Thierry.
Thanks for the info. I'll be around if you need any more infos from my side.
Cheers!
Posted: 11 Jan 2024, 12:14
by Acornspreader69
Any updates? I should start with a Lip syncing project soon.
Posted: 11 Jan 2024, 12:51
As a workarouond: could you convert and save the video to something else, like .mp4?
If you only need the audio, you can open the video in Audacity and export as .wav or .aif soundfile.
Posted: 11 Jan 2024, 14:31
by Thierry
Hi there,
We believe we have found what is causing the issue.
We'll try to have a working fix as soon as we can, no ETA yet.
Posted: 11 Jan 2024, 14:40
by Acornspreader69
Hello slowtiger.
.wav seems to do the trick. I guess that I just have to convert all the shots that I need. Tedious and time consuming, but at least it works. Thank you!
Thank you Thierry for the update.
Posted: 12 Jan 2024, 08:44
by rohandeshchougule
Hello mp3 works as well!
Posted: 23 Jan 2024, 13:45
by daninski
I have the problem with .wav. existing files that worked before that are embedded have developed clicks too.
I reencoded some as mp3 and they work like that, but there's too many files to do that and re import and retime them.
Posted: 24 Jan 2024, 14:23
by Matthieu
Hello everyone,
Just to let you know, the developers have found the cause of those audio issues and great progress has been made on the fix. We also found that some parts of the code could be responsible for other bugs regarding audio imports: we are working on rewriting them as well.
Posted: 27 Feb 2024, 09:13
by Acornspreader69
Any recent news on this problem / update?
Posted: 27 Feb 2024, 09:35
by Matthieu
Yes, those issues have been fixed by the developers. The fixes will be included in the software's upcoming update.
Posted: 05 Mar 2024, 09:14
by Acornspreader69
Nice! Thank you for all the work. Any idea when said update will get released?
