global variables? Topic is solved
Lukas
global variables?
Post by Lukas »
Is there a way to save something to a global variable?
For example, can I create a button with 2 actions:
action1:
GLOBAL myglobalvar = 4
action2:
name[1] = "HELLO"
name[2] = "EVERYONE"
name[3] = "AU"
name[4] = "REVOIR"
PRINT(name[myglobalvar])
To make the button print "REVOIR"?
If not, is there any other way to achieve something like this?
Also, is there a cleaner way to create arrays/tables or even structs in George? Or the name array above the only way?
  • LukasKrepel.nl
  • TVPaint Pro 11.7.5
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
Re: global variables?
Hi Lukas,
Took me a bit to understand, but George doesn't have software-global variables.
Variables in George are "restricted" to their own script and can't interact with instructions from another script.
However, I found a workaround for this, as I needed it years ago :p
You can use the command tv_WriteUserString to save a variable to your User Config, then use the command tv_ReadUserString to retrieve it.
In your case, the script could be written like this:
Action 1:
section = "globalGeorge"
name = "globalVariable"
tv_WriteUserString section name 4
Action 2:
name[1] = "HELLO"
name[3] = "AU"
name[4] = "REVOIR"
default = "not found"
tv_ReadUserString section name
val = result
PRINT(name[val])
And in theory it should work.
Unfortunately, not possible.
Lukas
Post by Lukas »
Ah! :) I remember using tv_WriteUserString a long time ago, had to see the function to remember it. That should work for my problem. Thank you!
  • LukasKrepel.nl
This is a thread that discusses tv_WriteUserString and tv_ReadUserString and also discusses a technique callsd "StringPacking" that you might find useful.
Also note the last entry in that thread shows a way to create a script for packing and unpacking values in an array, which might work for you.
sven
Lukas
Post by Lukas »
Very interesting Svengali, I'll try and wrap my head around that code. My George is very rusty, its quirks are quite hard to read and understand if you haven't touched it in a while. Thanks for pointing me in that direction!
  • LukasKrepel.nl
NathanOtano
Post by NathanOtano »
You can also store variables "per project" which can come handy :) https://wiki.tvpaint.com/index.php/Tv_W ... jectString
Also, you can write/read text anywhere in the clip dialogue/notes textboxes, project infos, and you can write text files with george
Lukas
Post by Lukas »
NathanOtano wrote: 01 Apr 2024, 13:53 You can also store variables "per project" which can come handy :) https://wiki.tvpaint.com/index.php/Tv_W ... jectString
Ah, good to know. Thanks!
  • LukasKrepel.nl
