I'm using TVP 11.7.3 Standard.
I have imported 2 .mp4 videos in my project. Then made some edits to the image layer from the second video. I only want soundtrack from the 1st one though. Now the problem is in the Sounds panel, I only see the sound track from the 1st video – which I can mute and control through there – but the soundtrack from the 2nd video is nowhere to be seen. How do I mute it, please?
How to control 2nd imported video's sound track? Topic is solved
Re: How to control 2nd imported video's sound track?
I'm not sure, but I think TVP standard only has 1 soundtrack at a time.
I just found a workaround – so for those who got stuck in the same situation:
1) Make sure you still have the 1st sound track source file.
2) Remove the visible 1st sound track (right click on soundwave in Sound panel -> Delete).
3) Reload sound dependencies to make the 2nd sound track appear in Sound panel (Clip -> Dependencies -> Sound Tracks -> Reload All Sound Tracks).
4) Remove the now visible 2nd soundtrack.
5) Import the 1st sound track back.
