[TVP12] Can't pick the dot on the top in camera speed curves. [TVPA-3577] Topic is solved
Can't pick the dot on the top in camera key gragh.
- jonathan_tvpaint
Re: [TVP12] Can't pick the dot on the top in camera speed curves. [TVPA-3577]
Thank you for your contribution. The team was able to reproduce the issue and is currently working on it. We will try to have it fixed in a future update.
We discovered you can still move these points (on top) if you try several times ( 3 or 4 times )
- jonathan_tvpaint
The team was able to solve it. The fix will be available in a future update.
