TVP12 crashes when switching between open projects while FX STACK PREVIEW is enabled [TVPA-3637]
Posted: 21 Jun 2024, 13:21
by Cardin
Just as the title says...
If you have two or more projects open, TVP12 will crash if you click on another project's tab button while PREVIEW is enabled on the FX STACK (must have at least one FX loaded in the stack for each project [edited for clarity]).
Crash also occurs if you attempt navigation to another project via the Main Menu Bar ( Project- Go to - "project name")
Re: TVP12 crashes when switching between open projects while FX STACK PREVIEW is enabled
Posted: 23 Jun 2024, 17:27
by Cardin
Adding video of bug as well as clarification that both projects need to have FX PREVIEW enabled and each have at least one fx loaded.
TVP12 FX Stack switching projects bug.mp4
(16.37 MiB) Downloaded 270 times
Re: TVP12 crashes when switching between open projects while FX STACK PREVIEW is enabled [TVPA-3637]
Posted: 28 Jun 2024, 09:49
by Kévin
Thank you for your feedback.
The bug has been fixed by the dev team. It will be available in the next update.
