MXF export format using the DNxHD or DNxHR codec
Posted: 21 Jun 2024, 22:57
To be able to export videos as MXF files, using the DNxHD or DNxHR codec.
Ffmpeg offers a version of the DNxHD or DNxHR codec which could possibly be an alternative to Prores, especially for Windows machines and/or Avid users.
DNxHR could be for 2K, 4K or 8K projects, and has no restrictions except for pixel format and minimum frame size, as far as I can see.
These are the 8 bit ffmpeg profiles:
DNxHD is quite restrictive, specially with the framerate, but for 720p or 1080p projects there are a few options.
The following would be the equivalent to Avid DNxHD 175 (which is 8bit) at 24fps:
EDIT from the 30/06/2024
Maybe, as a possible reason to support MXF export is the fact that mxf files can be compressed quite a bit when zipped. It is solely based on anecdotal evidence, but when compressing a mxf file into a zip, it reduces its size of about 80% or 90% sometimes or even more, like with this example, where a file that was 440MB originally weighted 30MB once zipped using 7zip.
- dnxhr_lb: DNxHR LB - Low Bandwidth. 8-bit 4:2:2 (yuv422p). Offline Quality
- dnxhr_sq: DNxHR SQ - Standard Quality. 8-bit 4:2:2 (yuv422p). Suitable for delivery format
- dnxhr_hq: DNxHR HQ - High Quality. 8-bit 4:2:2 (yuv422p)
ffmpeg -i input -c:v dnxhd -vf "scale=4096:2160,fps=24,format=yuv422p" -profile:v dnxhr_hq -b:v 746M -c:a pcm_s16le output.mxf
ffmpeg -i input -c:v dnxhd -vf "scale=1920:1080,fps=24,format=yuv422p" -b:v 175M -c:a pcm_s16le output.mxf
