TVPaint 12 User Manual / Documentation
Matthieu
Post by Matthieu »
Hello everyone.
The TVPaint 12 User Manual is finally online. You will be able to access it here: https://doc.tvpaint.com/
As I mentioned in another topic, it is still a work in progress since the aim was to completely rewrite the previous documentation and make it easier to follow through clearer formatting and GIF images.
A good part has already been rewritten and most of the new V12 features have been documented. However, the rest of the documentation is identical to the v11 one in content for the time being, save for screenshots which are missing on some pages.
French, Japanese and Chinese localizations will also be implemented in the future as well as a search bar function.
We will keep on working on the new User Manual and will try to complete it as soon as possible.
You will still be able to access the previous TVPaint 11 User Manual by clicking on the footer link of the new documentation or using this link: https://doc-tvp11.tvpaint.com/
Thank you.
Re: TVPaint 12 User Manual / Documentation
Matthieu wrote: 11 Jul 2024, 14:10 It is still a work in progress since the aim was to completely rewrite the previous documentation and make it easier to follow through clearer formatting and GIF images.
I am glad to see that work is continuing on updating the documentation.
Regarding screenshots and GIF images to make things clearer: may I suggest again that certain FX Stack tools such as Scan Cleaner and Black & White Converter (also in the section on Handmade Drawings > Clean Up) should emphasize how combining the Black & White Converter with Scan Cleaner can be used to remove red or blue colored pencil lines (underdrawing/construction lines) from scanned drawings, because in the previous documentation it was not explained how Black & White Converter FX can be of use in that task. See my previous post with explanatory screenshots here:
viewtopic.php?p=132150#p132150
(if you need them, I can provide you with clean screenshots without the explanatory notes I added to the screenshots)
So, using a combination of FX in the stack: Black & White Converter + Scan Cleaner , it is possible to prepare scanned hand drawn animation for coloring in TVPaint. I would also suggest adding a note to the documentation that if at all possible when scanning drawings with red or blue colored pencil underdrawing/construction lines it would be best to use a red channel filter or blue channel filter (depending on the colored pencil used for the underdrawing) within the scanning software to eliminate red or blue lines at the scanning stage , which means that there is less work for TVPaint to do in preparing the scanned images for coloring.
Matthieu
Post by Matthieu »
Hello David,
Those are excellent suggestions, thank you very much. I would be glad if you could provide clean screenshots without the added notes, indeed (or even better, the whole project you have used so I can redo the screenshots with V12's interface).
Also, please rest assured that I am keeping an eye on all the previous suggestions that have been made in the "user manual mistakes" topic when rewriting the documentation's content.
Mistakes in Manual:
Beyond spelling mistakes, I suspect some HTML strangeness, in how the mistakes below (and mistakes actually in manual) are displayed???
Arithmetic operators and examples
-negative: 18 -> -18
**exponent: 18**3=181818=5832 __________ should be 18*18*18 NOT 181818
multiplication: 183=54 __________________ should be 18*3=54 NOT 183=54
/division: 18/3=6
+addition: 18+23=21 ____________________ should be 18+3=21 NOT 183=21 AND NOT 18+23=21
-substraction: 18-6=12 __________________ should be subtraction NOT substraction
Logic operators and examples
&&an: a&&b should be __________________ should be &&and: NOT &&an:
||or: a||b
sven
Matthieu
Post by Matthieu »
Hello Sven,
Thank you for pointing this out. I finally have some time to focus on the manual again. I have done a small update on Guides, added the V12 changelogs and fixed the mistakes you have mentioned.
I will resume working on it and update it as frequently as possible.
Xavier
Post by Xavier »
Bravo Matthieu !!! I know it's a lot of work :wink:
Brian
Post by Brian »
Greetings to the topic, and the board! I'm Brian, and this is my first post here. ^_^
I've been trying to read and follow the online manual before really getting into TVPaint 12.0.2 Pro. I'm running a PC with Windows 10 Pro. Anyway, the program is fascinating, though I'm noticing in the Online User Manual that not all the example figures/graphics/gifs, are showing up despite there being references in the text that they should be there. I understand after reading this topic that it's a Work-In-Progress. I was wondering, is it being updated in a linear way? Going from the beginning to the end, or are they being updated by measure of importance in the program? And may I ask about how much has been updated with the picture examples and how much is left to do?
The last time I noticed the image not appearing, was on this page.
Instances:Application
https://doc.tvpaint.com/docs/animation- ... pplication
When I first came to this part a week or so ago, there were no images there, but when I went back to it a couple days after I tried the exercise, I refreshed the page and suddenly all these image examples showed up. I've slowed down a bit, due to IRL stuff I've been busy with, but right now I'm at this part of the manual.
Delete instance heads and exposure cells
https://doc.tvpaint.com/docs/animation- ... sure-cells
I don't see any images on that page or for several pages beyond that I've looked at so far just to see if there are any images.
I am viewing the manual in the most recent version of Firefox 134.0.2 (64-bit).
Do i need to try a different Browser? Or are these sections simply not updated yet?
I apologize for all the questions. I'm very new to this program and some picture-examples in the manual would help with these more technical parts of the program. If there's any questions for me, any info I might need to add, please let me know and I will do so as soon as I can.
Thank you so much in advance. ^_^
Matthieu
Post by Matthieu »
Greetings Brian!
First, let me apologize for this very late reply. I have somehow missed your message to this thread.
Unfortunately, the manual has not been updated for a while because I had to take care of other things. I estimate that new screenshots have been taken and uploaded for about 25-30% of the current version of version 12's manual.
For the first few months, the manual was not updated in a linear way and we followed this logic:
-I have almost completely rewritten the first manual first sections (in order to make some things a bit clearer and to give users a solid foundation in how TVPaint's interface and brush engine work -stuff that was sometimes evoked in later pages in the previous V11 manual). Those sections' screenshots were updated first.
-I have also written lessons for the V12's new features and uploaded screenshots for those as a priority.
-Finally, important topics (Pre/Post Behaviors ; Color Groups ; CTG Layers etc.) had their screenshots updated and uploaded. This is because those are features we are often getting asked about. Thus, we prioritized those sections over linear completion.
-Now that this has been done, the aim is to update the rest of the manual in a linear fashion.
Since most V12 features have been covered, you may find it helpful to read V11's manual here for sections of the V12 one which have not been updated yet. Some parts may need some additional details, but at least, you will find screenshots that would mostly still apply to what you will see when using version 12.
I will resume updating the manual as soon as I have some time to do so.
