Image Import in 11:73
Simon W Edmondson
Post by Simon W Edmondson »
My experience with 11:73 is limited due to other factors ( the splendour of V12 awaits ) but, having trouble with Image import.
Previously in earlier versions of V11, if I wanted to import an image sequence to work over or from, you'd go to File> Open/import, navigate to where the files were stored, click on 000, and it would bring them into to the current project. Were you could scale and position them as required.
Now, when the same process is attempted. It brings in the selected files, but, as a new project, at the scale of the imported file, and they can not be scaled or repositioned. When that is attempted, an alert sounds and an orange message flashes up at the bottom of the screen saying.
"Whats done can not be undone"
Clearly I'm making a mistake somewhere. Can someone kindly explain how to do it now?
Thank you
simon
Imac OSX 10:15:7 8gb Ram
Léo
Re: Image Import in 11:73
Post by Léo »
Hello Simon,
I think you simply chose the Project Tab instead of the Layer Tab in the Import Panel :
Enregistrement 2024-07-15 105705.mp4
(2.39 MiB) Downloaded 162 times
With the Layer Tab, it will import your files with the size of your current projet, etc...
Léo Fernandez
Wacom driver version 6.4.2-3
Simon W Edmondson
Leo
Thank you very much for your welcome reply.
regards
simon
