How to move multiple layers at once
mikdog
Post by mikdog »
Something is confounding me - I've created the animation for 2 characters that include a number of layers, and I want to shift/pan them all to the left as I've drawn them a little too far to the right.
However, having tried keyframer which results in multiple stamps of the image for some reason all shifted at various intervals to the left, and the transform tool on a colour group which appears to not pick up instances after the first couple of instances/exposures for some reason, I'm stumped - what's the correct way to move/pan all my character layers -250 to the left, please? :?
Any help greatly appreciated.
TVPaint Pro 11.7.5 Mac 64-bit, Mac Mini M4, 24gb ram, macOS Sequoia 15.5, Wacom Cintiq 22" HD driver 6.4.9-2, Apple Magic keyboard, wired logitech mouse, Crucial X9Pro ext SD drive which has my work, Western Digital ext drive for time machine backups, also backs up work folder on Crucial drive.
mikdog
Re: How to move multiple layers at once
Post by mikdog »
Figured it out - I think because I was using CTG layers that made things weird.
I converted all CTG layers to normal animation layers, and didn't select a source as the colour group.
It worked when I just kept it simple with Keyframer.
Didn't figure out how to get Transform to work, but Keyframer worked well for this.
mikdog wrote: 20 Jul 2024, 19:53 Figured it out - I think because I was using CTG layers that made things weird.
I'm glad you figured it out. I would usually just do this sort of function using the KeyFramer , but if you want to use Transform, be sure you select option Apply On All Layers or Apply on Selected Layers.
My go to, out of the box, method for shifting multiple layers is to use the crop tool.
to shift 250 pixels to the left, position the crop 250 to the right.
do not scale, just reposition (making sure none of your animation gets clipped) apply and voila all content is on its new position.
off course your back ground will be clipped so first copy it and past it back after the shift.
