I found difference of "Export to Project: Display" and "tv_SaveDisplay" george command.
Is it possible to resolve the issue of dpi not being reflected by the "tv_SaveDisplay" george command?
P.S.
I discovered the tv_GetExternalImageDpi command in the TVPaint12 documentation and confirmed that this function is also available in TVPaint11.7.3.
This addition is an important step forward in moving between paper and data.
Difference of "Export to Project: Display" and "tv_SaveDisplay" george command
- Hironori Takagi
Re: Difference of "Export to Project: Display" and "tv_SaveDisplay" george command
Hello Hironori Takagi,
When we use the George "tv_SaveDisplay" command, we save without specifying any resolution for the DPI.
By default, a saved image (JPEG, PNG) will therefore take the DPI of the project, if no resolution is specified.
And there is nothing to modify, via George, to modify this resolution.
So, if you save your project which has 300 DPI as a JPEG via the George command, the generated JPEG will have 300 DPI.
Léo Fernandez
Wacom driver version 6.4.2-3
- Hironori Takagi
Thank you for your response.Léo wrote: ↑25 Jul 2024, 08:13 Hello Hironori Takagi,
The attached image is a pointing out that when you run File > Export from the same project (150dpi),
the dpi is preserved (150dpi), but when you output the result with tv_SaveDisplay, the dpi is not preserved (not set).
By the way, with tv_ClipSaveStructure, the project resolution is preserved for jpeg and png,
but not for psd and tiff, which can actually record dpi, so I feel like this could cause trouble for users.
(I'm sure another user has pointed this out in the past)
Indeed, there is something we have to investigate, our devs will look at it as soon as possible.
Léo Fernandez
