posting embedded IMAGES on the forum Topic is solved
Recently I notice that I am no longer able to upload images to my post and use the option to embed the image in the body of the post.
When I try to upload images (or other files) to the forum I get a pop-up error message: "HTTP Error" . This has only started happening recently.
For now if I want to have an image embedded in my post I must post it to an external image hosting site and then embed it here using the IMG tags.
OR if I want to upload a .mp4 or .mov or .tvpp file to share , it is not possible , but instead I must upload the file to another site (Google Drive or Dropbox) to share it here.
This embedded image showing the Error message is hosted on another site. It is not possible for me to upload and embed this image directly on the TVPaint forum:
Re: It is no longer possible to post embedded IMAGES on the forum
Hi David,
That's weird, can you tell me how do you embed an image?
Do you go in the "Attachment" tab and add the image there?
//Edit: as you can see it is working
It seems to be fixed now. I have no explanation for why it happened , all I know is that for a day or so it became impossible to upload and embed images directly on the TVPaint forum. Uploading an image generated the error message that I showed in the screen capture above.
I'll mark this one as fixed. If it happens again, I'll let you know.
