I checked whether the custom panels I had created so far would work with TVPaint12,
and found that in many cases they did not work due to changes to the specifications of the camera layer, folder, and image mark.
I'll share one test I did, where I modified "TimeSheet" so that it would not stop in V12.
The main changes were:
- Determine whether it is version 12 or later or earlier
- For version 12 or later, skip layer types "Camera" and "Folder" when searching
- For version 12 or later, the information acquired for image marks has changed from "ID" to "ID R G B", so only the first part is acquired
There may be other specification changes, so please let us know if you notice any.
TimeSheetPanel(SelfCustomize)_240816
- Hironori Takagi
- sheet_inbetween8-2_240816.grg
- (26.98 KiB) Downloaded 1052 times
- sheet_inbetween_standalone8-2_240816.grg
- (50.86 KiB) Downloaded 1041 times
- sheet_key8-2_240816.grg
- (52.08 KiB) Downloaded 1013 times
- TimeSheet_240816.tvpx
- (287.5 KiB) Downloaded 1074 times
- NathanOtano
Re: TimeSheetPanel(SelfCustomize)_240816
Thank you!
