tv_projectsaveaudiodependencies and tv_projectsavevideodependencies
ademir.p
Post by ademir.p »
Does this command work?
Here is the link address to the documentation:
https://doc-tvp11.tvpaint.com/index.php ... pendencies
I was thinking that it would do the equivalent to Project -> Dependencies -> Embed audio dependencies, now
Any ideas?
Windows 11 Pro, 64-bit, 11th Gen Intel(R) Core(TM) i7-11370H @ 3.30GHz, 16 GB RAM
TVPaint Animation 11 Pro WIBU (11.5.3-64 bits)
Re: tv_projectsaveaudiodependencies
There's something missing in the documentation for this one, you need to get the project's ID first, and set it as parameter to the command.
Here's how you should use it:
tv_ProjectCurrentID
projectID = result
tv_ProjectSaveAudioDependencies projectID true
We'll update the documentation this week.
ademir.p
Post by ademir.p »
Hi Thierry,
Thanks for the quick response.
I confirmed this with brunchstudio on the git repo pytvpaint. You can find the full conversation on the github issue here.
Here are the most important details from the github issue:
The audio dependencies are not saved even when calling
directly in george from tvpaint,
tv_ProjectSaveVideoDependencies
doesn't seem to work either. They both return a
code which in TVPaint usually means an error occured. There is no documentation for any of the above george commands or their return codes. This is all that is provided:
[DESCRIPTION]
[DESCRIPTION]
Thanks for updating the documentation on
While you update the documentation would it be possible to update
as well?
I'm assuming it would be the same fix.
ademir.p
Post by ademir.p »
Hi Thierry,
Hope you are well. Just pinging this. 8)
Thierry wrote: 23 Sep 2024, 11:47 We'll update the documentation this week.
