Specifying RGB numbers? Topic is solved
BruceM
Post by BruceM »
How do I specify RGB numbers to create a specific color? Can you do this in TVPaint?
Re: Specifying RGB numbers?
Use the "slider" option of the colorpanel.
Or select a value and type the numbers. Tab gets you to the next field.
BruceM
Post by BruceM »
Excellent! Thank you Peter & Slowtiger!
BruceM
Post by BruceM »
Slowtiger, can you clarify what you mean by "tab gets you to the next field"?
BruceM
Post by BruceM »
Also, if an RGB color is specified and I type those three sets of numbers into the Slider window, will the color appear in the A-B window?
BruceM
Post by BruceM »
Slowtiger, disregard those last two questions. I figured out the "tab" part.
Thank you!
