monitor scaling causing an issue
Posted: 01 Feb 2025, 18:31
by Peter Wassink
I reported a scaling problem with the startup panel before..
I found out what the problem is:
It has to do with the windows monitor scaling.
When you work on two monitors that have different scaling in windows " System>Display " the startup panel gets mangled.
in my case, normally my main (large) monitor is at 150% and my 2nd (smaller cintiq) is at 100%
when i open tvpaint on my main and move the startup panel to the cintiq it gets cropped.
when i set both to 100% the startup panel stays the same
when i set the cintiq to 150 and the main to 100% its the other way around
screen resolution issue 2.jpg (12.11 KiB) Viewed 20787 times
screen resolution issue.jpg (31.84 KiB) Viewed 20787 times
