AfterEffects Import TVPaint JSON.jsx script not working in latest AE2024 and AE2025
ademir.p
Post by ademir.p »
Hi,
One of our projects need to use the 'AfterEffects Import TVPaint JSON.jsx' to import their JSON exports from TVPaint into After Effects. They need to deliver very soon.
The JSON exports from TVPaint 11.7.1 look good. However, when we select the JSON file with the 'AfterEffects Import TVPaint JSON.jsx' in After Effects nothing happens.
Are you able to assist?
Kind regards,
Adi
Windows 11 Pro, 64-bit, 11th Gen Intel(R) Core(TM) i7-11370H @ 3.30GHz, 16 GB RAM
TVPaint Animation 11 Pro WIBU (11.5.3-64 bits)
Re: AfterEffects Import TVPaint JSON.jsx script not working in latest AE2024 and AE2025
Hello, are you using the latest version of the script, available from the documentation?
https://doc-tvp11.tvpaint.com/files/les ... 20JSON.zip
