TVPaint Animation 12.0.3 is available!
Locked
Hello everyone!
2025's first update is here, fixing some old Wacom bugs, introducing lots of George commands for CTG layers, fixing issues with custom plugins, and more.
What’s new in TVPaint Animation 12.0.3?
Timeline:
  • CTG Layers: you can now use "Transform into Anim Layer" on multiple CTG layers at once (selected layers).
  • Added a "Fit to camera" option in the Timeline.
  • Clicking on the layer folder creation icon when a layer is selected should put this selected layer into the folder.
  • In Storyboard view, an option has been added to create a new project from each selected clips.
  • Camera Layer can now be deleted when it is the current layer.
  • When increasing exposures on an instance, if you have several instances selected, all instances will gain exposures.
George:
  • George commands to handle CTG layers:
    Spoiler : CTG commands :
    • Create a CTG Layer:
      tv_CTGLayerCreate name [source1] [source2] ... [sourceN]
      returns layerID
    • Load Structure from Sources:
      tv_CTGLoadStructure ctg_ID
    • Assign layers to a CTG:
      tv_CTGSource "add" ctg_ID source1_ID source2_ID ... sourceN_ID
    • Remove a source:
      tv_CTGSource "remove" ctg_ID source1_ID source2_ID ... sourceN_ID
    • Apply changes:
      tv_CTGApplyChanges ctg_ID "on/off"
    • Squiggles visible:
      tv_CTGSquigglesVisible ctg_ID "on/off"
    • Query layer sources:
      tv_CTGGetSources iCTGLayer
      returns layer1 layer2 ... layerN
    • Check if the current layer is a CTG source:
      tv_LayerIsCTGSource
      returns oCTGLayerID1 oCTGLayerID2 ... oCTGLayerIDN if yes
      returns -1 if no
  • New commands to manage scenes:
    Spoiler : Scenes commands :
    • Create a scene with 2+ clips:
      tv_SceneCreate iClipId1 iClipId2 … iClipIdN
      returns oSceneId
    • Split a scene:
      tv_SceneSplit iSceneId
      returns oClipId1 oClipId2 … oClipIdN
  • New George commands for Image Library:
    Spoiler : Library commands :
    • Export:
      tv_LibraryImageExport iPath
      Return:
      0: success
      -1: error on iPath
      -2: other error
    • Import:
      tv_LibraryImageImport iPath
      Return:
      0: success
      -1: error on iPath (incorrect, not found)
      -2: error on reading (access rights for example)
      -3: other error
    • Create a folder from a Layer:
      tv_LayerCopyToLibrary iFolder iLayerID_1 iLayerID_2 ... iLayerID_N
      Return:
      0: success
      -1: error
  • New optional parameter for tv_LibraryImageAdd to add all images of the current custom brush:
    tv_LibraryImageAdd "type" "image" "name" iName "parent" iId "source" "currentlayerimage"|"display"|"custombrush"|"custombrushall"
  • Image Library George commands are now undoable
  • Add a parameter to tv_LayerMove to take into account a folder:
    tv_LayerMove iPosition [iFolderID]
    If iFolderID is not given, the layer will be moved in the "root" folder.
  • New command to get Camera Info at a given frame:
    tv_CameraInfoFrame iFrame
    returns oX oY oAngle oZoom oCameraWidth oCameraHeight
General:
  • In the Shape Settings panel, all sources can now be assigned with shortcuts, and you can cycle between sources with a shortcut.
  • Anti-Aliasing is now correctly applied to the Pespective Tool.
  • Added a "Lock Preview" option on Transformation Tools: preview only affects the currently locked frame(s).
What has been fixed and/or improved in TVPaint Animation 12.0.3?
Drawing:
  • Horizontal lines should no longer appear out of nowhere when drawing.
  • [WACOM TABLETS] Hover click mode now works in Wintab + Subpixel mode
Camera:
  • Project > Render Camera in New Project no longer inverts layers' order.
  • Cropping a project no longer makes the "You cannot use this tool on a Camera layer" pop-up appear on the new project.
  • Camera spline speed curves no longer have strange angles.
Timeline:
  • Removed some empty spaces in the Timeline GUI to make it look closer to what it was in v11.
  • Timeline can once again be scrolled in Project View after pausing playback.
  • Fixed a refresh bug that could happen when transforming a CTG layer to an Anim layer (or vice versa).
  • Fixed a crash that could happen after transforming an Anim layer to a CTG layer.
  • Updated opacity tooltip for the Layer Folder.
Storyboard:
  • Project view thumbnails are no longer refreshing when you select another Clip.
  • Clip Thumbnails preview is no longer distorted when the Camera's resolution differs from the project's size.
  • Hidden Clips are now correctly marked as hidden.
  • Camera no longer flickers when scrolling the Timeline in Project > Thumbnail view.
Rigging:
  • There should no longer be a gap between the bone's border and the bone itself.
George:
  • tv_LibraryImageInfo no longer returns an error when searching on objects.
  • tv_ProjectInfo no longer returns the field parameter
  • When using tv_LayerDuplicate on a layer in a Folder, the duplicated layer will now be in the Folder.
  • Fixed various issues with the tv_ShapeTransform command.
General:
  • Having a paper toggled on no longer causes the non-drying to behave like drying.
  • Fixed an issue with the Undo function when cutting and pasting images on the same Library.
  • DPI value is no longer reset when a project is cropped.
  • Playback button allows previewing FX stack once again.
  • Fixed some font issues in Chinese and Japanese localization.
  • Fixed French localization that was present in non-French languages.
  • Increased the size of many HUDs (Camera, FXs...).
SDK:
  • Fixed an issue causing custom plugins to either crash when loading or cause a TVPaint crash.
  • When opening a new PIFilterReq, it will no longer appear in the top left spot of the TVPaint window.
  • If you coded a plugin, we strongly recommend switching from using DWORDs to INTPTRs in your plugins for better 64-bits support.
macOS:
  • Fixed an issue that prevented the menu bar from stop working in the Standard Edition.
  • Cmd + A shortcuts are working once again.
Ben_QuadGroup
Re: TVPaint Animation 12.0.3 is available!
Post by Ben_QuadGroup »
Thanks for the update,
One minor element that make me doubt that the update worked is that the version in the exe metadata indicate 12.0.2:
Locked
