weird bug v12: dropdown menu only works on the left half of my second monitor?
the weirdest bug.
I noticed i could not activate the pull down menu to load a file, the "file" button in the top menu did not respond.
but the "help" button did. when i shifted the main tvpaint interface to the right side, more of the panel buttons became active/clickable.
i had to shift it far to the right to finally be able to click the "file" button.
this invisible border between where my buttons are clickable and where they are not was about right through the middle of the screen.
after trying out more i noticed other menu items are also affected by this weird behaviour.
while i can click on toolpanel items when the interface is on the left i cannot click any pulldown menus.
for instance the color panel allows clicking a/b color but i cannot choose a different colorpaneltype from the pull down.
and again it did work normally once i shifted the compleet TVPaint interface to the right side of the screen.
Do you know what this could be ? something that only affects pulldown menus on the left side of the screen?
this on my laptop scaled way down to 1920x1200 with a second monitor at 1920x1080
the issue happens when i have tvpaint on the second monitor... when i shift it on the primairy monitor (that of my laptop) the issue is gone.
it looks like this is probably related to other double monitor issue. for now i just had to switch off my second monitor because its not possible to make use of it when working in v12.
Re: weird bug v12: dropdown menu only works on the left half of my second monitor?
Hello, this is probably linked to the multiple monitor issue that some users have been experiencing indeed. We are still investigating it.
