TVPaint 11.7.5 bug - camera view functions not working. Topic is solved
ChristopherC
Post by ChristopherC »
Hello, a couple of issues i've found is that the camera preview functions don't seem to be working properly in 11.7.5.
1. 'Preview: Toggle Play with Camera view' and 'Preview: Activate Play with Camera view' are not functioning at all, including the interface toggle in the screenshot below.
2. jumping to a cropped playback of the camera view doesn't seem happen anymore when during playback and having camera turned on.
the cropped automatic preview of clip thumbnails when hovering over the clip seems to be working just fine with the camera view, just not the full window preview on playback.
(MacOS 15.4.1)
Re: TVPaint 11.7.5 bug - camera view functions not working.
Hello Christopher, we tested this on MacOS and Windows and things seem to work as expected.
Does the issue still occur with a fresh config?
ChristopherC
that has fixed the problem, thank you :)
ChristopherC
Hi just an update, since initially fixing the problem, the issue keeps repeatedly coming back up after a number of days using tvpaint, causing me to reset my configuration and go through the process of resetting my workspace, shortcuts, colour groups and preferences. i'm experiencing the same issue as Milkdog with the playhead skipping along the timeline also. this has happened for the 4th time i'm reverting back to an older version of tvpaint before whatever the preview playback changes were made that seem to have broken a lot of functionality.
