Crippling bugs.
RjLikesToDraw
Crippling bugs.
Post by RjLikesToDraw »
12.0.3 is definitely far better than the original 12.0 release, but I've still run into some nasty bugs that I never had with TVP11
1: Sudden ctrl + z ghost.
  • I can not for the life of me figure out how to duplicate this bug but it's happened enough times to be absolutely infuriating. Imagine just drawing - No hand on the keyboard, no finger anywhere near a button on your tablet then suddenly as you lift your pen, Something I can only describe as a hacker-ghost decides to ruin your day. You watch as everything you drew systematically gets deleted in sequence like somebody pressed Ctrl + Z the maximum number of times... Then the drawing vanishes and suddenly a preview plays. When I tried to Redo, I realize in horror that I can't. After undoing everything it activates another completely random action (like the transform tool) to completely block me from reclaiming what I drew. It's like the program itself just threw all my work out in the most disrespectful way possible. With no control to stop it.
    One thing when you're sketching, but a whole other beast when you're doing delicate inking. You can easily lose 10 minutes worth of work, and I'm the kind of person who saves every 10-15 minutes.
    If anybody else knows this bug or can duplicate it, please post examples of it here.
2: Tabbing over changes tools.
  • I switch to my browser or discord and flick back to TVP, my tool will completely change to a tool I haven't used in ages. Lets say I use the Sketch Panel's blue pen without anti-aliasing, I tab over and it's suddenly the soft pencil tool with the color set to red.
    Sometimes if I tab over and back again, it switches back to the tool I was using before the change. Other times You're stuck with this new tool, gaslighting you as if you used it. I actually thought I was going crazy the first of many times I encountered this bug. This adds a LOT of extra button presses to the process and makes the overall process feel more like a chore. Its entirely random when it happens.
3: Tablet Pen Eraser tool stays locked in.
  • Self-explanatory. I flip my pen to eraser and it erases. Then TVP will not register my pen flip back to normal and it stays on eraser. Flipping a pen is instant and intuitive just like a real pencil. This extra time spent to go hunt down the tool I was using before adds up on animation projects. I often have to reset when this happens because once you see the bug once, it stays during your session.
4: Random fill tool tomfoolery
Different bugs related to the fill tool.
  • For no reason the tool will just reset to default. Sometimes on program startup. Sometimes as I flip to another tool and back. If you had a perfect setup including specific colors to exclude from the sketch panel this is a serious time-killer.
  • Normally, Right-clicking undoes paint. This is a very cool and clean feature that I adore. on a Cintiq pen, this maps to the bottom button - Until it randomly isn't and the bottom button will randomly flood the rest of the unpainted screen, ignoring closed lines.
  • If for whatever unholy reason you have to use transform on your aliased lines, (this itself is subpar and creates nasty misaligned pixels. I understand the logic of the software, but Please if you can program a fix to that, please do - Yes I check off "none" on the anti-aliasing box) After you spend 20 minutes recleaning the lines you modified and check for gaps and then use the fill tool, it will randomly flood the rest of the unpainted screen. I've experimented when this happens. That frame becomes "bad" and this effect locks on that specific frame. If you save and restart TVP, it behaves normally again.
I really hope 12.0.4 I'm running into bugs far more frequently than I've ever run into any version of TVP 11. TVP is my favorite animation software easy, but right now it's below the old reliable TVP11 I fell in love with. Please help.
Re: Crippling bugs.
Hello, sorry for not responding to this thread earlier, I thought I had but it seems that my message wasn't posted.
Which operating system and tablet model do you use? Is your tablet's driver up to date?
Out these 4 issues, #3 rings a bell for me and I will conduct tests for #4 soon.
#1 is something that we haven't ever heard of, if you managed to capture it on video, it would help a lot.
Did you import some configuration files/keyboard shortcut sets from TVP11 into v12?
Do these issues still occur with a fresh configuration?
Re: Crippling bugs.
re #1: does this happen in other programs too? This sounds a lot like a broken keyboard, I had strange stuff happen once I spilled some coffee over one of mine ...
Re: Crippling bugs.
slowtiger wrote: 02 Jun 2025, 17:47... a broken keyboard,..
was gonna suggest the same, or maybe a stray cable touching a key.
Maybe good to know the U key also does Undo (stemming back to TVPaints AMIGA days)
