Shortcut command to return project window to normal size? Topic is solved
BruceM
Post by BruceM »
I'm still having one issue with programming a mini keypad with TVP shortcuts, which is: what command on the right side of the shortcuts menu do I use to return the project window to its normal size?
Say that I've been zooming in and drawing and now I want to pop the project window back to its normal size. What command does that?
Thanks!
Re: Shortcut command to return project window to normal size?
you can hover over buttons in the interface to find their name and shortcut
what normal size do you want? you can use these commands depending on what you need
zoom 100%
zoom fit
BruceM
Post by BruceM »
Zoom Fit works!
Thanks Peter!
