hello i just installed both pro and the original version of TVPAINT.
and it dun work.
i get an error message from windows saying that it couldent execute.... (the regular stuff windows says).
and thats befor the intro image comes up just when im about to run it it fails.
AppName: tvpaintanimationdemo.exe AppVer: 8.1.1.0 ModName: wintab32.dll
ModVer: 2.0.0.4 Offset: 0000466f
i dont know what the hell that means but it sure aint good.
i tried out mirage way back when and it worked great this doesent even try.
what is up?
i dont think ive restarted my computer tho might be that ill check back but im kinda thinking it wont work yet.
ill give it a try and say if it dident.
NO that did not solve the problem..
HELP ?
Windows error on launch.
Re: Windows error on launch.
hi Mistchiff, and welcome!Mistchiff wrote:hello i just installed both pro and the original version of TVPAINT.
and it dun work. ...
what do you mean by "both pro and the original version" ?
do you mean demo versions ? ... registred versions ? ...
what do you call the "original" version ? CD from the box ? ... TVPA Standard edition ?
which version ? ... the last public release v.8.5.8 ?
did you unintalled previously any existing version(s) on your system ?
did you intalled them in "modify", ... "repair" mode ?
have you installed firstly the Standard edition ?
... and after having checked that it worked, installed the Pro version ?
... in the same folder? ... then checked if it worked, but it didn't ...?
then both the 2 versions didn't work at all ?
have you try to uninstall both, then re-install only the Pro version,
and see what happens, if it works or not ?
as your case seems a bit special, more details would be
very appreciated.
thanks to help us to help you.
oh, I forgot,
in first, can you check whether you really have this Wintab32.dll file
in your C:\WINDOWS\system32 folder ?
because if not, no need to go further ...
(try to re-install your tablet driver in that case)
This post also has nothing to do with it, i'm just observing that you are very creative with english to come up with a word that has only 3 google hits.
wtfoxorz ?
wtfoxorz ?
