"Your Brushes"
"Your Brushes"
Anytime that I make a new brush and use the (grab tool only)-arrows to collect them in the ''your brushes'' panel, the brushes are randomly placed which takes a lot of space. Does anyone how to re-arrange them in an orderly way, i.o.w., how to edit the panel?
Re: "Your Brushes"
I never use the arrow button, precisely because that reason .
I right-click where I want to place my tool in the Custom Panel,
then choose int the menu "Grab Current Tool"
that said, an easy way (drag and drop) to re-organize the tools
in a custom panel would be welcome.
select it by draging a box around it (them).
add new line, add vertical separator(s), ...
re-arrangement is not so easy, but already possible
after an amount of efforts.
You can cut/copy/paste the tools,hisko wrote:... i.o.w., how to edit the panel?
- CPedit.png (26.66 KiB) Viewed 12027 times
Re: "Your Brushes"
Thanks, I know how to cut and paste the tools, but when I paste them they are never on the exact spot that I wanted.ZigOtto wrote: I never use the arrow button, precisely because that reason .
I'll use the "Grab Current Toll"in the menu from now on, but you are right, it would be good if it were made possible to drag and drop the toolbuttons. (I know that for some reason, in Painter that isn't possible either)
Re: "Your Brushes"
Hide Icons names.
- ShowIconOnly.jpg (20.19 KiB) Viewed 12003 times
Hervé ADAM, TVPaint Team
Re: "Your Brushes"
Thanks, that works, so then it's important that I make good icons for my brushes.Hervé wrote:Hide Icons names.
