Hi,
I just started using tvpaint using a friend's computer and it seems to suit what I'm doing well.
My problem is the following:
I need to load a video to edit, but TVPaint crashes every time I've tried to load it into a project with the same frame rate. I've tried several times adjusting the different settings such as Preload, stretch, etc. However, it loads sometimes when I load it into a project with a different frame rate setting. I'm slightly worried about changing the framerate, etc (there is audio it is synced to).
The file properties are:
avi 1.0
divx5.03
119.881FPS
704x396 pixels 1.0
latest version of tvpaint regular
sytem specs:
vista 64
xeon
nvidia quadro fx
I tried searching the forum and FAQ but didn't find a solution. Any help is much appreciated.
Thanks!
TVPaint crashes when loading a video at certain frame rate
Re: TVPaint crashes when loading a video at certain frame ra
119.881FPS ???itaru wrote:... 119.881FPS
what for such a high frame rate?
