timeline
Posted: 19 Dec 2007, 12:51
by A1
Hi,
a small question:
Is there any way of making the timeline stop from skipping to a selected layer?
Posted: 20 Dec 2007, 09:19
by A1
Maybe it can be a feature request then(?)
Perhaps a toggle on off : snap to current layer.
just a suggestion.
Re: timeline
Posted: 20 Dec 2007, 12:34
by ZigOtto
A1 wrote:... making the timeline stop from skipping to a selected layer?
I don't get what you mean by that ...?
Posted: 20 Dec 2007, 19:34
by A1
My bad!
i should have given some more info, so here it goes:
For example: if i have a certain layer selected, and i scroll up or down in the timeline to
adjust another layer: move the animation 2 frames to the left for example
without selecting that layer (and i don't just so that i find the (still selected)
layer that i'm animating on easily ), then i want to see what i did by using the arrow keys to flip the frames, the timeline jumps back to the selected layer.
So if i want to adjust the non selected layer one more frame i have to go look for it again. I almost always end up working with alot of layers, and it gets very hard to tell one from the other.
I hope the above is comprehensible. If not i'll try again :wink:
Posted: 23 Dec 2007, 13:32
by A1
never mind,
I'll try again when my project is finished and i have the time to make
comprehensible sentences.
In the mean while i guess i'll just have to deal with it.
Posted: 23 Dec 2007, 17:40
by ZigOtto
well, I think I've understood your point, but I hadn't a straightforward solution immediatly,
are you already using the layer color-gadgets to visually differentiate them ?
also, I'm thinking of a couple of CP buttons (via george scripts),
one to record (write) the currently selected Layer ID,
the other to select ( read & go to) the last written layer ID,
but I'm not sure it will be a great benefit...
have to think about it a little more ...
Meanwhile, have a good time and merry Xmas to you. :)
Posted: 23 Dec 2007, 19:53
by A1
I did try some alternative approaches, but to no avail.
I think the timeline has some shortcomings in general when it comes to
dealing with a lot of layers.
I'll make some humble suggestions at a later time.
Thanks for your input and Happy holidays!
