A little splashy turtle.
djm99001
Post by djm99001 »
This is hopefully the beginning of a freelance project.
I did 8 drawings on paper, then scanned, re-timed, in-betweened, inked, and colored in TVPaint.
http://www.youtube.com/watch?v=tldMlhFxS5g
Enjoy!!!!
David.
toonsisters
Post by toonsisters »
Dear David,
Seems to be fun, I like it.
let's get to see more of it!
Vera
cute turtle! :D
it seems to suffer from a severe case of footmorph though. :wink:
djm99001
Revision
Post by djm99001 »
Alright, alright. I inked and cleaned it.
I'd like to hear from anyone who does clean 2d animation entirely in TVPaint--my process was pretty slow for this and definitely needs suggestions. I had about eight layers -- first, the initial 8 drawings on paper, timed out with holds. Then, a blue pencil layer done in tvpaint, all 24 frames, rough animation. Then I (needlessly) spread the inking across several layers, and finally slid the color underneath.
I discovered that the blue needs to be well constructed if the inking is going to go quickly. I had to construct those morphy feet in the inking stage.
I'm doing nine more animals in this style, for the freelance project.
David
http://www.youtube.com/watch?v=AWC_e3ZU22M
inking could be done on one layer indeed.
a feature that might help you during cleaning is to open open a secondary project window ( short cut 'm' ), now set one window at 100% magnification this is so you can see how your ink-line will look in the end result,
you can use the other window to do the actual drawing and zoom in on the part you are cleaning.
a comment on your cleaned turtle.
When its head moves back to the begin position it loses volume and shape, it looks very morphed there.
multiple project windows handy for cleaning
djm99001
Post by djm99001 »
Thanks for the inking tip. I knew about the "m" key but I never thought to use it for inking. Seems obvious now.
I cleaned it up further, and actually reshaped the head, since the client said it was too "alien-like."
http://www.youtube.com/watch?v=MyICG9jXoec
It got distorted because I didn't anticipate youtube rescaling it like that....
