Remove image button
Remove image button
We need for the Animator Panel a special delete frame(s) button that will offer options: 1. to remove without having layer move to the left
2. to ask: current layer only? all layers?
If this already exists, I apologize. I've searched the best I could, by which I mean I have not looked into the x-sheet, which I don't expect to ever use, and the same goes for the Instance Panel. I think this should be a simple addition to the handy Animator's Panel.
Re: Remove image button
Paul Fierlinger wrote:...
haven't you gone in the project menu?
Duplicate, Insert, Delete Image, Add exposure, ... are commands working on all the layers, except the locked ones.
(I have buttonized a couple, but they still need icons.)
8)
What/where are project menus?
File Edit Project ... , so the third up-right corner, not changed since Mirage.
Have you read my entire post? After all these years do you really believe that I would only now be asking how to delete an image?
I answered to your point 2 :
... current layer only? all layers?
- for current layer : the old way,
- for all layers of the project : Project/Delete Image
:roll:
In the Mirage Animator's toolbar we had one button which did all of my points. Life becomes much easier to bear when the layer doesn't move left from its position when a frame or sequence of frames is removed.
ematecki
Post by ematecki »
So it's more like 'clear frame' than 'delete frame' ?
(Because layers can't have 'holes' in the middle)
To have a cutsom button 'ask a question', you'll have to write a george script.
Should be quite easy, anybody ?
personnaly, I think a button embeding 2 functions, I mean systematically opening a question
(options to choose) and waiting for an user's answer, is a bit tedious when using it a lot.
I prefer by far 2 different buttons, each one operating straightfully its job, just by 1 click.
that's a matter of taste, and all tastes are in the nature.
I did mean cut (delete) not clear. Typically I would use it only at the head of a layer. In the middle it behaves the same as the classical delete image.
Paul Fierlinger wrote:... Typically I would use it only at the head of a layer.
in that case, I would stretch/drag the head-handle of the layer, (Cut Images mode),
or I am missing something again ?
Well, that's where the All Layers? option comes into play. It's more efficient than having to select all layers, drag handle of current layer EDIT: right and select Cut Images. This is also used in the middle of a layer where typically I would have placed a hold on all layers and now want to shorten the whole scene by a few images. Essentially it comes to cutting out a one or more images from the middle of a project.
When Sandra paints our scenes, she might have 10 or even 30 layers of just paint variations. If I later decide to delete something, it has to happen on all layers. But sometimes I need to just trim the head of a layer without throwing the layer out of sync with all the other layers -- thus option: Current or ALL Layers?
Paul Fierlinger wrote:... This is also used in the middle of a layer where typically I would have placed a hold on all layers and now want to shorten the whole scene by a few images. Essentially it comes to cutting out a one or more images from the middle of a project.
in that case, the Instance engine can do that :
Ctrl A to Select all Layers,
then click & drag in/out the Tail of the Hold Frame you want to shorten/lengthen in the middle of your layer.
the timing change should be applied on all the selected layers.
(the condition being to have tails aligned in each selected layer)
OK, I should have not said hold frames -- it could be any piece of animation (but it's good to know about the hold case :) thanks).
There would be a simple solution to this -- maybe. Can the George script from Mirage be copied into TVP? When I tried to use the Mirage custom panel with this button on it, TVP crashed. But since it IS a George script, couldn't one of you techie wizards just adapt it to TVP's George file?
