Align Left & Right
Align Left & Right
I can't get this function to work either with the designated buttons on the Animator Panel or the drop down menu in the layer panel. What could be going wrong? I can make it work from dhomas trenn's ToolBox so it's not my computer system.
Re: Align Left & Right
You need to select the layers you want to align before you can apply the function.
Standard multi-selection keys are used : shift, ctrl.
Click on the layer icon to select, double-click to select all layers.
Selected layers have a yellow frame around the icon.
(Paul, I know you are aware about the layer selection method, but I'm sure this post may be useful to new TVPaint user, so I try to give more informations.)
Manuel
well it does work here, but differently I think :
- I make my current frame the frame (timeline position) where I want the alignement,
- I select the layers I want to align,
- hit the [align to left] button > it will align all the selected layers, heads on the current frame,
- hit the [align to right] button > it will align all the selected layers, ends on the current frame.
Got it! Thanks to both of you. It's different from what I had been using.
Zig, I just got to use your way in a real situation. It's clever. I usually know where I want to move something and with long timelines it's a bitch to drag on frame all over the place until you land where you need to land. This is one of those useful nothings that make life a pleasure.
