SDK question -- new plugin, how does it get loaded?
- idragosani
OK, this might seem dumb, but...
I have a built a test plugin using the SDK (compiled on the first try!). I have a DLL file and I have put it into the Plugins directory. Now how do I get TVP to load it? Do I need to put into a list somewhere? Is it supposed to be automatic? If TVP is trying to load it, how can I diagnose this? Is there a log somewhere so I can see startup errors?
Re: SDK question -- new plugin, how does it get loaded?
The plug-ins are loaded at starting sequence. They should be listed in the Windows/plugin menu.
Manuel
- idragosani
Yes, they *should* be, but they aren't. That's why I am asking how to diagnose startup issues.Manuel wrote:The plug-ins are loaded at starting sequence. They should be listed in the Windows/plugin menu.
have you tried to re-start tvpa ?
also have you tried to add an action in a Custom panel,
and line 0 RMB/Set Plugins ... to see if it appears in the popup list ?
- idragosani
Yep, tried that, too... is there any way to tell if there is an error while loading?ZigOtto wrote:have you tried to re-start tvpa ?
- masterchief
Place it in the plugins folder... I created an SDK folder inside my plugins folder and all SDK samples are placed there so they do not get lost. works here
ex: BOTH fade.dll and fade.loc need to go in folder together if you start with fade example
regards,
William
regards,
William
TVPaint Animation Pro v11
- idragosani
I did put in plugins folder, but no loadie.masterchief wrote:Place it in the plugins folder... I created an SDK folder inside my plugins folder and all SDK samples are placed there so they do not get lost. works here
regards,
William
Where do I get the .loc file? What needs to go into it? I didn't see any instructions in the SDK documentation, although I see where in the code it tries to load it. Maybe that's why it fails to load... but it would be nice to have some kind of logfile that one can enable for debugging purposes.
- idragosani
Never mind, I see how these .loc files work. There isn't one bundled with the flip source codemasterchief wrote:Place it in the plugins folder... I created an SDK folder inside my plugins folder and all SDK samples are placed there so they do not get lost. works here
- idragosani
OK, so I built with MS Visual C++ Express ... same problem. Plug-in is not getting loaded.
I repeat the question: is there any kind of startup log that can be enabled to debug the loading of plugins?
Is there any general way of debugging a plugin while it is running?
Interesting I had the same problem also building C++ express, It was my first time in compiling, so I abandoned it
because I thought I simply couldnt figure it out..
I was actually thinking If somebody who know hav to compile knows which soft ware to use borland c++ or microsoft express
Could make a tutorial for absolutely programming beginners. because I would reallt like to learn to make plugins for my favorite software
-mads
-mads
Here is the project for VC2005
- Flip.rar
- (24.76 KiB) Downloaded 303 times
Hervé ADAM, TVPaint Team
- idragosani
It also builds in Visual C++ Express 2008, if you know how to set up a Win32 DLL Project. Same goes for building in Eclipse.madsjuul wrote:Interesting I had the same problem also building C++ express, It was my first time in compiling, so I abandoned it
I just need some advice on how to debug a plugin when it is being loaded into TV Paint. The loading information goes by so fast on the TVPaint screen at startup that I can't see any messages!
- masterchief
I compiled the fade plugin using Visual Studio 6.. works great.... I have not figured it out using Code::Blocks IDE with the mingw compiler..
I prefer to stay with the opensource platform
regards,
William
regards,
William
For VC2005 or VC2008idragosani wrote: I just need some advice on how to debug a plugin when it is being loaded into TV Paint. The loading information goes by so fast on the TVPaint screen at startup that I can't see any messages!
Set the output file in the TVPaint plugins folder: Configuration properties->Linker->Output File->"C:\Program Files\TVPaint Developpement\TVPaint Animation Pro\Plugins\flip.dll"
Activate the debug mode: Configuration properties->Linker->Debugging->Generate Debug Info->Yes
Set the exe file: Configuration properties->Debugging->Command->"C:\Program Files\TVPaint Developpement\TVPaint Animation Pro\TVPAnimationPro.exe"
Add a break point in the PI_Open function
Start Debugging ( F5 )
- idragosani
Thanks much! I've never done DLL debugging before (my experience is more in Linux & Unix development).Hervé wrote:For VC2005 or VC2008idragosani wrote: I just need some advice on how to debug a plugin when it is being loaded into TV Paint. The loading information goes by so fast on the TVPaint screen at startup that I can't see any messages!
