Update TVP Animation 8.6.1
Hi all,
We release today a new update for TVP Animation Standard and Professional Edition. This update is the 8.6.1 version and fix some bugs and behavior:
-Fix the Sharp, Tint and Colorize mode,
-Fix the registration ( 30 days ),
-Fix Clear Frame when the FXStack Preview is active,
-Add Ctrl D 18 to activate the full Antialised preview mode ( experimental only, not optimized now )
-Fix the Help.
You can download the update by using the "Check for updates" function in the "Help" menu of the TVP Animation or use the update page on our website for TVP Animation 8.x.
Hervé
-Fix the Help.
Hervé
Hervé ADAM, TVPaint Team
Re: Update TVP Animation 8.6.1
Should I assume that one should select "Repair" and not "Modify" in the InstallShield Wizzard?
Well, I'm in a mess. I was too impatient to wait for the answer and went ahead the way I presumed I should, selecting "Repair". Now I get a dialogue box saying that my dongle isn't present (it is). It further says to re-plug my dongle and click OK to contiue, so I removed it and replugged it, pressed OK, and TVPaint vanished.
What now? Please don't make me wait too long.
I uninstalled TVPA and reinstalled 8.6 and all is fine. But before I did that I tried installing 8.6.1 and the problem prevails so I'd say there's something wrong with that version.
- Klaus Hoefs
I did the maintanance with ("Modify").
But after installing-process and starting TVP - it says still version 8.51US
- Klaus Hoefs
So I have to go to 8.6 and then to 8.61 ????
And why isn#t there an error-message when coming from 8.51 ???
- idragosani
Wow, you guys have been busy!
- idragosani
Installation went fine for me, but I am having the dongle problem. Wondering if we need to install new driversPaul Fierlinger wrote:I uninstalled TVPA and reinstalled 8.6 and all is fine. But before I did that I tried installing 8.6.1 and the problem prevails so I'd say there's something wrong with that version.
- Klaus Hoefs
-o.k.
I uninstalled my working 8.51
-installed 8.61
--> no dongle recognized, crash ! (Paul here I am...)
-installed 8.61
So what's so fine about installing with the dongle problem? 8.6.1 is useless isn't it?
Uninstall again and reinstall 8,6.0 and don't trust anyone over 30.Klaus Hoefs wrote:-o.k.
-installed 8.61
- idragosani
Yep. 8.6.1 ain't working.Paul Fierlinger wrote:Uninstall again and reinstall 8,6.0 and don't trust anyone over 30.Klaus Hoefs wrote:-o.k.
-installed 8.61
- Klaus Hoefs
I installed with the sentinel driver option too - doesn't also work.
OK, It's a bad build for some of you who use the Mirage dongle, sorry
The correction comes in a few minutes
The fixed version are online.Hervé wrote:OK, It's a bad build for some of you who use the Mirage dongle, sorry![]()
