watercolor
Klaus Hoefs
watercolor
Post by Klaus Hoefs »
I know this is an old hat, but I like to bring it up again:
It’s MoXi, the digital painting technology:
Well anything like that with TVP in sight ? Remembering Raymond's Chinese Brush from long time ago and taking the innovations of TVP into account - at first glance it doesn't seems to be too difficult to get s.th. like this. --- (????)
video-demonstration at youtube:
http://www.youtube.com/watch?v=UwcYP2KMgFc
their site:
http://visgraph.cse.ust.hk/MoXi/ --scroll a bit down to see more videos.
Hoefs 19.jpg (15.79 KiB) Viewed 24250 times
__________________
http://www.khoefs.de
Re: watercolor
ah ... moxi ;)
Some brushes of the Creation Pack have a watercolor rendering (there is a watercolor panel, btw) but to have a such spread (diffusion ?) effect, my best advice is to use the particle FX with a recorded stroke.
nb : the new wet brush profil of the v9.0 may help to get better result than before
Klaus Hoefs
Re: watercolor
Thanks for the hint, Fabrice.
The standard "watercolor-palette-brushes " are looking to me like transparent-pastel-airbrushes. Watercolor flows more, even if you have put the brush away from the paper and has this typical fringe you can see it in the last picture I posted.
Anyway when having a little bit more time I will try to get closer to this.
__________________
sury rony
Re: watercolor
Post by sury rony »
I had almost reasonable results using the water color brush with hard edges and then "watering" it with the healing brush set on paper as source.
But not on blank page , you have to flood fill the background.Play with it.
I couldn not understand the wet brush profile handling and uses... can some one further explain it ?
edit : seems like the moxi guys sold the patent to adobe, but they are open to suggestions , and looking for descent artists for beta testing.
Klaus Hoefs
Re: watercolor
yes they sold it non-exclusively to Adobe and Sony. The guy was programming the handling of the avatar-brush at first and for a long time, well this could be skipped in TVP.
The difficulties:
-the peculiar behaviors of blending watercolors
- the drying phase and result, very different to other colors and techniques
- the flowing of water, thinning the color
__________________
Re: watercolor
I tried Moxi last year (before I was hired by TVPaint) and I have to add those points (pro and cons ...)
1°) the canvas is in 3D, and not really convenient for painting. (the viewed 3D image is not exactly the same that the one obtained after the 2D rendering phase)
2°) the number of parameters is really high, everything can be set (almost 1/3 of the screen is dedicated to the option !) but unfortunalety not intuitive : drying, flowing and blending options are not easy to find and set to obtain good results.
3°) it needs a specific hardware : a powerful NVIDIA 3D video card + a 6D art pen from Wacom. (TVP with the particles system mentioned above doesn't need all that stuff.)
4°) Once mastered, it's possible to obtain very good renderings :)
5°) I sent them some feedbacks, but no answer unfortunalety :(
hisko
Re: watercolor
Post by hisko »
Fabrice wrote:I tried Moxi last year (before I was hired by TVPaint) and I have to add those points (pro and cons ...)
The watercolor from Moxi looks very interesting.
But could you maybe explain more about the way particles can be used to make a brush?
Klaus Hoefs
Re: watercolor
Fabrice wrote:(TVP with the particles system mentioned above doesn't need all that stuff.)
That does make sense to me, an emitter with slow explosion-like settings and a appropiate particle picture(s) as it's shape could perhaps simulate the flow.
It isn't too far away from one of those predefined "smoke"-emitters.
__________________
Re: watercolor
Yes, just set the gravity to 0 and the job is quite done with the "heavy smoke" preset.
After this, you only have to choose a new particle file (a scanned stain of watercolor should be ok, for instance)
