George : Rounded Polygon (TVPA 8.6 & >)
Manuel
Post by Manuel »
Here are 3 scripts and a custom panel in a tvpx file.
Installation :
Copy the 3 scripts in your George folder.
Drop the tvpx file in TVPA (version 8.6 and above), it should install the custom panel.
For each action, assign a script :
1: PolyRounded.grg , it will draw a filled shape
2: PolyLineRounded.grg , it will draw with lines
3: PolyRoundedSet.grg, it asks you radius and level values
Use LMB to draw the lines, RMB for the last point.
If you want a corner NOT rounded, double-clic.
___________________________________________________________________________
Une série de 3 scripts qui vous permettront de dessiner facilement des polygones aux angles arrondis.
Installation
Copiez les scripts dans un dossier, installez le panneau personnalisé et refaites les assignations de chaque bouton.
1: PolyRounded.grg , dessine un polygone plein
2: PolyLineRounded.grg , pour un polygone creux
3: PolyRoundedSet.grg, pour définir la taille de l'arrondi, en pixels, et son niveau de fractionnement.
Bouton gauche pour pointer chaque sommet, double-clic pour un angle non-arrondi.
Bouton droit pour le dernier sommet.
Example (rhôôô le zôli phylactère biscornu)
Polyrounded.zip
3 scripts + tvpx
(7.27 KiB) Downloaded 344 times
Manuel
Re: George : Rounded Polygon (TVPA 8.6 & >)
super cool, le truc ideal pour les BD et mangas :)
Sierra Rose
Post by Sierra Rose »
Manuel, I got lost somewhere in this. I got the 3 files into the George folder. But where do I put the tvpx file? I tried putting it loose in the TVPaint Pro folder but it loads and when I say OK on the "Loading extension" folder it just disappears and doesn't load anything. I also have lost the ability to load the Creation Pack Trial since I got my new computer back and installed everything on it. I must be using the wrong folder?
EDIT: Nevermind on the Polygon one...I got it...but not the Creation Pack trial. Was there a time limit on that one?
WinXP 32bit 10.0.17Pro
Sierra Rose
I'm sorry to bug you again...but the polyset one only gives me a filled rectangle with no rounded points.??
Manuel
Post by Manuel »
The PolyRoundedSet.grg script should only ask you 2 values. These values are used by the 2 other scripts.
It will draw nothing.
If you have just created a filled polygon before, TVP selects the fill rectangle tool when the script is done, I don't know why.
So it is only the rectangle tool that you are using, not the script.
Manuel
Satrip
Post by Satrip »
Hi,
Could it be possible to customize the PolylineRounded script to draw an unclosed line, not a closed polygon ?!
I've tried to do it myself with no success..
Help please :!:
PS: Very good scripts, congratulations to you Manuel!!! ^^
