Marker Toggler Cutom Panel
Mads Juul
Post by Mads Juul »
I Really like buttons that toggles between 2 states.
So I made this to buttons that works on Mark in and Mark out
The button for Mark in Toggle works like this:
-if You are ON the a frame where "Mark In" is set . mark in is set to start of project
-If You are NOT on the same frame as "mark in" . "Mark In" is set to that frame
and vica versa with the mark out panel
the buttons auto matically enables the mark in mark out because I "Disable them by moving them to the start/end of the project
which have the same effect
hope some find it usefull
-mads
marker_toggler.tvpx
(143 KiB) Downloaded 296 times
Re: Marker Toggler Cutom Panel
mads, it's a small thing but in a big way it's wonderful! Just brilliant. I keep the two buttons without the labels right below the PLAY button, dead center of the Project window, and I can reach it with my stylus and there's no more left, right, left, right -- searching for the Mark In/Out buttons to turn the tabs off and on. Great buttons.
Sierra Rose
Post by Sierra Rose »
I've been wanting this for the longest time. Thanks so very much.
WinXP 32bit 10.0.17Pro
Mads Juul
Post by Mads Juul »
Glad to hear the buttons are usefull and you like them
:D mads
