import photoshop layers
Posted: 21 Nov 2008, 17:51
by arche75
Hi~
I want to load photoshop layers sequensces like... Please refer to the images.
What should I do? How can it be done?
I have seen george script some time ago. I'm not so sure.
Can you tell me how to solve this problem?
Please tell me... Thank you..
Re: import photoshop layers
Posted: 21 Nov 2008, 18:04
by Hervé
Hi arche75
Load your PS file, use the "link layers" function in the animator panel and merge all layers.
Posted: 21 Nov 2008, 18:48
by Sewie
I didn't know that was possible. Great option !
Posted: 23 Nov 2008, 15:31
by arche75
Thanks a lot Hervé
Posted: 24 Nov 2008, 00:31
by meslin
Is there a way to turn a sequence back into a layers?
Posted: 24 Nov 2008, 00:56
by Paul Fierlinger
Probably just using "Split Layer" in the Animator panel, frame by frame. Mirage once had that plugin so I'm sure someone here would know how to make it again. I'd have use for it myself, for instance when working on animatics.
Posted: 24 Nov 2008, 03:28
by ZigOtto
meslin wrote:Is there a way to turn a sequence back into a layers?
yes, create a new button and set Keystroke :
Layer: New Layers From Selected Image
then, if needed, you can add other commands (see pict.) to align all at left.
at first, you have to select your range of frames, then, just hit the button.
Posted: 24 Nov 2008, 09:09
by Paul Fierlinger
Gee, thanks. I must try it soon.
Posted: 01 Mar 2014, 11:49
by boufertus1
Hi! I have the same question as the one initially posted here. But I cannot see how 'merge all layers' will put them as frames in a sequence, as specified above. It just merges them all on one frame. Can you help?
Posted: 01 Mar 2014, 14:41
- import that PSD file, now you have a bunch of layers
- select all these layers
- go to Animator Panel > Clip > Link layers (third icon)
- done.
Posted: 01 Mar 2014, 22:05
by boufertus1
aha i see thanks so much!
