How do I create backgrounds with Mirage
You got a problem with Mirage or Aura ? Tell us here.
JM07
Post by JM07 »
I know this is basic, but I tried reading the manual, but to no avail.
The type of background I want to create has to extend beyond the frame, so I can scroll it in or out. The backgrounds I have created so far, with Mirage, can't be scrolled without it permenently vanishing when scrolled out of the frame.
I appreciate your help.
JM07
Re: How do I create backgrounds with Mirage
Create a new project in the dimensions of your background. Paint it. While this project is open, return to your animation project. Open FX stack, Keyframer. Use the BG project as source.
JM07
Post by JM07 »
Thanks. I'll give it a try.
JM
JM07
Post by JM07 »
Well, I tried but failed to find what I was looking for. Under windows I found the FX Stack. I opened it and found at the top, an "Add FX" option, "Options" option, and "FXBin". So I opened "Add FX" and I see, Blur, color, distortion, keying, motion...." So I open up the Keying option and I read, advanced keyer, alpha control....etc.
So where do I go from here? I checked out the manual but search shows lots of results, but much to wade through. The manual is useless. It's just a big brochure that tells what you can do (and what it means) with Mirage without telling you how to do it.
You've been very helpful in the past, and I'm thankful, but my education level regarding this software is very deficient and any extra help is certainly appreciated. I think what I will do, if I get past this one, is make a clear education video on how to make and use backgrounds with Mirage, and post it so we can refer others to it when the question arises. I'll do this in appreciation of your effort.
Thanks for your help.
JM07
Hi JM07,
As said somewhere else, some video tutorials will be posted soon. It's just a matter of days. :)
Open FX stack and select KeyFramer under Motion. This will serve your camera move needs. You will find two black tabs; Position and Render. Start with Render/Source/Project List, where you will see your BKG project. Select it. Create a new anim Layer where you wish your background to appear in your current project window.
Open Position Tab. Look at the bottom of the FX Panel to find Preview. Make the image in your project window smaller than the frame and you will see the yellow binding box. Place your cursor on the first frame of your camera move, then click on the C button next to the X and Y buttons. This will create your first key on your timeline.
Place your cursor now on the last frame of your presumed camera move. place your cursor on the center of your project window, in the little green square. Now drag that green square to where you want your background to stop. Look at your timeline and you will see that you now have a keyframe bar stretching between the two keys. Highlight those frames and press the long button at the bottom of the KF panel, called Apply FX Stack.
Hope this explains what you are looking for but it's just the start; there is so much more you can do with the Motion KF.
Paul Fierlinger wrote:... there is so much more you can do with the Motion KF.
and so much more without KF as well ! :wink:
