How to import images?
rygoody
Post by rygoody »
Can TVPaint import images into it's timeline?
I have a video that I want to draw on top of.
rygoody
Re: How to import images?
Post by rygoody »
nevermind i found it, im a tard
just drag the footage or image onto the layer window
idragosani
Post by idragosani »
You can also use the Open File dialog -- it will provide you with lots of options for importing footage (like start and end frames, aspect, etc)
ButtercupSaiyan
Post by ButtercupSaiyan »
When I do this, it just makes a completely new project. I would like a single image in the background. I do not want a new project with new dimensions.
You just use "open", choose pic, hit OK, and then select what you want: new project, or layer in existing project. Beware of size changes (stretch to project size, correct aspect).
BCS, I advise to follow the userguide, step by step :)
Léo
Post by Léo »
You have to choose Layer and Single Frame in the "Open File dialog", as follow:
Léo Fernandez
Wacom driver version 6.4.2-3
