Flip a sequence horizontal, is that possible
Hi there
I'm trying to Flip a sequence horizontal, is that possible??? (meaning that I want to invert my animation)
and also when I use the transform tool to manipulate many images at the same time, when I apply it adds images(inbetweens) into my shoot???
cheers
/Tommie
http://www.pigbelly.com
cheers
/Tommie
- malcooning
Re: Flip a sequence horizontal, is that possible
1. Modify > flip horizontallypigbelly wrote:Hi there
2. undo
3. select all frames
4. Enter
As well, if you want to only see it flipped, without really flipping it, you can set it in the View menu.
Asaf | asafagranat.com
oohhh
cool
BUT its creates a frame per frame if you know what I mean?? I mean I have lets say 6 key frames for a sequence of 30 frames, after modify I have a key per frame...
/T
cool
/T
Layer -> Exposure -> Recompute Exposure, will remove all unnecessary frames.
- malcooning
Beat me to it.
And if you find yourself doing this operations sequence often, just create a button for all these actions.
here is a image reference of my problem:
Before I modify. after.
cheers
/Tommie
cheers
/Tommie
Great!!!! Love you guys
But i cant help to think that maybe the re-compute thing should be dafault???? can one put it to default??
cheers
/T
cheers
/T
- malcooning
It's a matter of preference. Probably I agree with you: TVP should check if there are instances in the layer, and if so, recreate them after the flip. But since the process is fragmented (you apply a single flip to each frame on the timeline via applying the last action, aka Enter) it is difficult to implement it.pigbelly wrote:Great!!!! Love you guys
cheers
/T
The most natural way to apply a flip should be to apply it to Instance HEADS only. This would also flip the layer more quickly (calculate times).
In the meantime, you can make it a default behavior for yourself by making a button of the actions you did to flip the layer and recompute frames.
ohh didn't know you could do actions??
/T
/T
- malcooning
well, it's not really recording actions (like in photoshop), just recreating them as commands in sequence in a custom button. It's not the most intuitive, but very efficient.pigbelly wrote:ohh didn't know you could do actions??
/T
- malcooning
Tommie, if you set your button like this you'll get a nice general automation of re-applying any last action on instances only. Can be used with anything that can be applied on singles frames.
Thanks Zigotto for pointing to this script line.
well, to answer to Tommie first question, I think the easiest way
to Horizontal-flip a selection of frames without breaking the Instance's exposures
actually is to make yourself a Hflip custom button with this single command : see attached pict.
but I agree this can be add to the future requests list :
- make the Horiz./Vert./Both Axis Image Flip commands repecting the Instances
(working on Heads only).
tv_cmd heads tv_FlipImageX
- hflipheadsonly.png (5.54 KiB) Viewed 28983 times
- malcooning
cool. I wasn't aware the 'heads' is usable in all those forms.ZigOtto wrote:well, to answer to Tommie first question, I think the easiest way
actually is to make yourself a Hflip custom button with this single command :see attached pict.Code: Select all
