wiggly line
BenEcosse
wiggly line
Post by BenEcosse »
This is something basic I'm sure. I'm drawing characters for HD, I was drawing quickly at 33% screen zoom and my lines looked fine. Then when I viewed at 100% there seemed to be a sort of distorted.
Can anyone suggest how to avoid this?
Re: wiggly line
What size wacom do you have? and what size screen?
When you'r project is zoomed out during drawing you are also using a smaller part of your drawing tablet for each line.
This means in effect less resolution in the recording of the stroke.
This can be the cause of the effect you show us here.
a solution (if you don't have a big monitor) is to open a second project window for your project ( use shortcut key M)
then have one window show a total view (so you have an overview of the whole screen) at say 30%,
and one window in which you actually draw and that you zoom in, say at 200%
BenEcosse
Re: wiggly line
Post by BenEcosse »
I've got a INTUOS A5 WIDE wacom and 2 x 1920x1200 monitors. Wasn't sure if I should stretch TVPaint over 2 monitors or not?
I'll try opening up a second window like you said and draw 100% in the main window.
thanks
Re: wiggly line
BenEcosse wrote:I've got a INTUOS A5 WIDE wacom and 2 x 1920x1200 monitors. Wasn't sure if I should stretch TVPaint over 2 monitors or not?
thanks
an A5 wide should do fine if you draw at 100%
if you do stretch over two monitors you can leave one project window entirely filling one monitor in the 100% window (HD = 1920 right?)
and put the overview window (30%) with the rest of the panels on the other screen.
here you see an example of two windows of the same project
BenEcosse
Re: wiggly line
Post by BenEcosse »
Working much better now, thanks for the help.
BenEcosse
Re: wiggly line
Post by BenEcosse »
here is finished clip
Re: wiggly line
Ben, there is no sound.
Re: wiggly line
Klaus Hoefs
Re: wiggly line
Post by Klaus Hoefs »
Paul Fierlinger wrote:Ben, there is no sound.
Here, too.
__________________
http://www.khoefs.de
Sewie
Re: wiggly line
Post by Sewie »
Ben, here too.
BenEcosse
Re: wiggly line
Post by BenEcosse »
I know, there is no sound
Klaus Hoefs
Re: wiggly line
I wonder about one who can do any character design and animation in a project without having any idea of the soundtrack (> 50 % mood). So what will happen if they will come back with Donna Summer, Heidi, ZZ Top ? Strange world.
Anyway I like your style which is looking free and straight. Curious about your new project !
__________________
