Layer ReTimer Tool
Posted: 08 May 2009, 15:46
by ZigOtto
- retimer.png (3.36 KiB) Viewed 3683 times
Here's a little custom panel (.tvpx file) to help you for retiming an AnimLayer,
3 preset-buttons to shrink the layer's length to t/2, t/5 and t/10,
+ 1 button to retime the layer to N frames (N = nb of frames for the new layer's length).
NB: it works
without interpolation .
Re: Layer ReTimer Tool
Posted: 11 May 2009, 07:21
thanks a lot for this zig
Posted: 29 Jul 2009, 20:42
by CartoonMonkey
Do you think you could make this tool work on a selection, rather than a whole layer?
I love this tool by the way!
C
Posted: 29 Jul 2009, 21:03
by ZigOtto
donno,
possibly if these commands are existing (?) by using tv_LayerSplit (?) + tv_LayerStretch on the good part,
then tv_LayerJoin (?) to get the 2 (or 3) layers in a single one back ...? really donno ...
Posted: 01 Aug 2009, 19:01
by Gochris1
This looks like a terrific tool, and I am looking forward to using it.
How do you plug it into TV Paint? I have downloaded other plugs ins from this forum but haven't been able to figure out how to use them. Is there a page in the instruction book covering this?
Any help is appreciated.
GoChris
Posted: 01 Aug 2009, 21:06
by ZigOtto
what tvpa version do you have ?
what I use to do with .tvpx file (I run a V9.0), is firstly to drag&drop the file into the tvpa window,
then, ... after clicking "ok", right-click the custom-panel button from the main bar,
the name of the new loaded panel should appear in the list of the menu, select it.
it should be stored now in the right-side panel bin, upper position.
Posted: 04 Aug 2009, 07:15
by Gochris1
I am using TVP version 8 Pro.
Posted: 21 Aug 2009, 10:16
by ubik
Salut Z,
for the "dummies" in animation,
can you explain and show your toolbin with an simple example?
thanx
Posted: 21 Aug 2009, 11:58
by ZigOtto
ubik wrote:Salut Z,
thanx
to show it ?
see the picture of the panel in the first post.
to explain what ? ... it's self-explained (re-timer),
how to use it ?
select your animlayer, click on one button, and see what happen.
... an exemple ?
suppose you have to rotoscope a piece of video (25fr/s),
- load the part of your video file you have selected for rotoscoping,
- click on [
T/2] button, (it will delete one frame on two),
- now you can begin to draw over, on a new animlayer,
- when your drawings sequence is finished, "select all" and click [+1] exposure (Instance Panel),
so the initial timing is restituted, you can export now at 25 fr/s
and post the video art on dailymotion.
Posted: 01 May 2014, 19:32
by furushil
Thank you for this panel! Just what I needed right now. It works with TVP 10.5.5
Is it possible that the frames remain on 2s when I hit the t/2 button?
Right now when I have something on 1s, I hit the t/2 button to delete every other frame and the layer "shrinks".
Then I select all frames an click on the +1 Exposure button. Is is possible to skip the last step?
Edit: Oh, yes, you described it the same way in your last post. Anyways, thank you for the panel.
Posted: 07 May 2014, 13:46
by ZigOtto
furushil wrote:...
you can add the commands you want to the [t/2] button by editing it.
