"HP TouchSmart" touchscreen computer
To talk about anything else
I saw a demonstration of animating a walk cycle on the HP Touchsmart computer ---
Has anyone used the HP TouchSmart with TVP ? I'm curious how it compares to working on a Cintiq.
In the demonstration above it looks a little bit "laggy" and doesn't have the familiar Wacom pen buttons and eraser.
(notice in the demo she's using the end of a paintbrush to draw with ... the TouchSmart picks up any movement of any object
touching the screen , so you could draw with your finger if you wanted to , or any object as long as it is not sharp metal which would
scratch the screen) . I can't figure out if HP has an optional pen stylus available for the TouchSmart . However, I think not having a Wacom-style pen
might be difficult to get used to. I looked on the HP Touchsmart forums and found this remark about using a stylus with the HP TouchSmart:
"Note that the TouchSmart screen is not a stylus-type digitizer as found on many tablet PCs or on Wacom tablets. The TouchSmart screen uses infrared cameras and LEDs to detect objects. If your stylus has a long, narrow tip, that produces a smaller shadow for the cameras to detect."
There's a portable model (12" inch screen) and desktop models (22" and 25" inch screen) . If the Desktop version could be mounted on an Ergotron arm
then it could be tilted and rotated like a Cintiq.
http://www.ergotron.com/Products/tabid/ ... fault.aspx
Hervé
Re: "HP TouchSmart" touchscreen computer
Post by Hervé »
The big probleme for me, it is not possible to put his hand on the screen.
Hervé ADAM, TVPaint Team
Hervé wrote:The big probleme for me, it is not possible to put his hand on the screen.
Ah, I think I see what you mean ... it would only be possible to write or draw with the tip of the stylus touching the surface , because if the hand contacts the surface
the hand will also leave an impression on the screen . So we would be restricted to holding the stylus in a certain way to make sure the hand does not rub on the screen.
just watching him paint/draw/erase gave me the creaps like scratching a blackboard with your fingernails. It looked actually painful.
Paul Fierlinger wrote:just watching him paint/draw/erase gave me the creaps like scratching a blackboard with your fingernails. It looked actually painful.
It does indeed look very slow. That is why I wonder if the lag shown in that video is because of the program being used or if it is the Touchscreen computer that is responsible for the lag.
I wonder how it would be using TVP with this HP Touchsmart computer.
I am curious enough about it that I may try to find a local computer store which sells this computer to ask if they will download trial version of TVP to the HP Touchsmart to let me try it in the store.
Would it not be a hindrance to your drawing abilities that you cannot rest your hand on the surface while you draw? This looks like painting with a long brush while standing a couple feet away from the canvas. I think this is why the process looks so stressed and uncomfortable.
idragosani
Post by idragosani »
Yeah, it's like drawing in slow motion or something... it would make me very fidgety!
