Popup Menus to set Line size and color
Here are two other simple menus that popup at cursor position... for setting Line Size and A&B Color.
Line sizes default to:
1, 3, 5, 7, 9 and 15 but you can use a text editor to substitute or extend your own list of line size choices by editing this line:
tv_ListRequest "1|3|5|7|9|15|"					// display list options
(Decimal values will work too.)
Note the popup menu color choices are restricted to black, white and two gray levels and may not be of much use to you. Here are those menu options:
tv_ListRequest "Black |White |Gray |PickPixel |SwapAB"	// display menu options at current pen position
Assign each script to a custom button and then assign those to keyboard shortcuts to activate popup menus.
LineSize&ColorMenu.zip
(1.1 KiB) Downloaded 279 times
