Hey,
Is there any way we can create/install new CURSORS additional, or replacing the exisiting ones?
A.
custom cursors
- malcooning
- malcooning
Hey N.
Thanks for the patch offer. I followed Raymond's suggestion to use Restorator, so I created new cursor with Artcursors and saved them as .cur files and then replaced them with the existing 'circle' and 'dot'. I've attached jpgs of them below.
I didn't take the time to learn how to create patches, but maybe once I do I can post it up in the forums.
Cheers,
Asaf
Cheers,
Asaf
- pen - smaller.jpg (941 Bytes) Viewed 23075 times
- pen.jpg (1.03 KiB) Viewed 23069 times
a "must-have" would be to have the ability to swap between your 2 or 3 most favorite Cursors
via shortKeys or CP buttons,
for example, to swap from "Left-Up" to "Left-Down", and vis-versa, or from your "pen" to your "small one".
I would love that!
I would love that!
- LeftVersions.png (2.73 KiB) Viewed 22725 times
- malcooning
- malcooning
I was pre-supposing new cursors implemented in the main code (extending the basis library), not through a patch.malcooning wrote:but if the cursors can be changed noly via patching, is there any way to implement such shortcut?
Of course I don't want to belittle the power of the programmer
it would be fantastic to swap about your cursors. the potential of different cursors for different usages is amazing.
just throwing ideas for new features in the next TVPA version or TVPS(?)
I wouldn't dare ask that!malcooning wrote:but the ultimate blow of all cursors in the world will be a cursor that rotates with the tilt and angle of the stylus!
the ultimate, for sure, though I guess such a feature would tax time-computing,
and considerably slow down the "realtime" drawing display, unless you have a 5Ghz quad-core cpu machine...
(hope I'm wrong !)
