hi guys, i`m just beginner in this software
so i had a problem with panorama moving on the background,
this software is so unlike others..
this problem is which i can`t solve, though i`m searching for the solution nearly 1month..
i`m using version PRO V8.5.4
Need some Help with Panorama
Sandro Katamashvili - 2d Animator
http://www.vimeo.com/user1584959
Re: Need some Help with Panorama
I'm not sure if with "panorama moving on the background" you mean a background pan, but here you can find some info on that:
http://www.tvpaint.com/forum/viewtopic. ... pan#p18275
http://www.tvpaint.com/forum/viewtopic. ... und#p12001
Hi sandicosandriko wrote:i`m using version PRO V8.5.4
begin to update (Help/Check for Update ...) to 8.6 ...
Hervé ADAM, TVPaint Team
thanks guys, i found this posts very interesting..
but i cant update my soft
The informations you sent are not correct. Please contact TVPaint.
Dear Sandriko,
The codes you have provided in the update/upgrade page are wrong.
Please send a copy your invoice to support [at] tvpaint [dot] fr to prove that you are not using a pirated or cracked software.
I will then send you a download link.
i have an extra question..
while working with Keyframer i discovered that inbetween images are not the same shape as originals.. here i uploaded the screenshots
i wonder how can i solve this problem?
I think you've created a file with fields. You must have to work with intrelaced files. To change it, please go into "Project => modify project => Fields : interlaced"
thank you very much
there was no interlaced option in field and i set it to progressive.... now its okay
thank you very much
you're right It was progressive, not entrelaced, I didn't use the good term (even if it's the same result).
