tv_readtextfile how?
Mads Juul
Post by Mads Juul »
How does it wotk?
I want to read to content of the file "C:/test.edl"
should this work?
tv_readtextfile "C:/test.edl"
And is the result the content of the text file?
-mads
Hervé
Re: tv_readtextfile how?
Post by Hervé »
tv_readtextfile linenumber filename
return linenumber and line readed or EOF if the linenumber is after the end of the file
example:
text = ""
loop = 1
line = 0
while ( loop==1 )
    tv_readtextfile  line "c:/windows/system.ini"
    parse result eof string
    if ( CMP( eof, "EOF"  ) == 1)
         loop = 0
   else
          text = text""string
    end
   line = line + 1
end
tv_warn text
Hervé ADAM, TVPaint Team
Mads Juul
Post by Mads Juul »
Ahh thank you Herve
in the Changes.txt in the SDk it says
tv_readtextfile FileNumber FOLDER_Name
it is a little confusing ;-) it should be changed to
-Mads
