Set toolmode or issue shortcut commands from george?
KenC
Post by KenC »
Is there a function that sets the current drawmode of the selected brush? Like line, freehand draw, elipse, floodfill etc..
I'm trying to create a popup menu with tv_listrequest that allows me to pick tools and assign a shortcut to this script. Then I have a way to select tools without moving my pen to pick tools as the popup menu follows the mouse position.
Or perhaps a way to fire of tvpaint shortcut (Control+k) commands from george would be even better. That way I could create a dummy palette with the tools I want and create a popup menu to select from those.
Also, is there a way to insert a menu seperator into the popup from tv_listrequest? I tried using "-" but that doesn't work.
There's no place like ~/
Re: Set toolmode or issue shortcut commands from george?
KenC wrote:Is there a function that sets the current drawmode of the selected brush? Like line, freehand draw, elipse, floodfill etc..
tv_setActiveShape
singledot|dot|flood|freehandline|freehandfill|linefill|line|splinefill|spline|rectfill|rect|ellipsefill|ellipse|selectrect|
selectellipse|selectfreehand|selectspline|selectflood|cutrect|cutpoly|cutfreehand|cutflood|crop|panning|position|
wrap|zoom
KenC
Post by KenC »
That's why I couldn't find it, it's not in the list of commands in my SDK docs.
Thanks.
probably the sdk doc needs a little refreshing update,
I think it will come with the (coming soon) v9.5 release.
stay tuned. :)
KenC
Post by KenC »
Great. Thanks for the updated list.
Hi Ken,
Here's a little script (for TVP 9) that displays info on the current tool and parameter settings... very useful for viewing all the parameters (and their order, which is important when writing script commands to set specific parameters...) Assign it to a button and you can review the current tool at any time.
When 9.5 comes out I'll release an updated ActiveToolInfo.grg. The 9.5 tv_GetActiveShape command parses the extended info a little differently.
ActiveToolInfo.grg
(2.76 KiB) Downloaded 170 times
KenC
Post by KenC »
Thanks Sven, that will come in real handy.
btw a switch/select case statement would be a super addition to george imo :D
