First I have to say, I like the 9.5 Version a lot!
Thank you very much for redesigning the panels. I think they are much more intuitive now, especially the animator panel.
I am still missing an exposure function:
deleting a keyframe by turning it and its exposure additionally to the last keys exposure, so that the whole timing is not affected.
Did I miss it somewhere?
And if not, can anyone talented pass me a george script, that I can create a button myself?
Thanks for considering.
Vera
Animator Panel
Re: Animator Panel
hi Vera,
If you're looking for a Delete Instance button, but working without changing the global timing of the layer,
you can try to import this tvpx file, and copy/paste the button into your Animator Panel /Instance section.
hope it will do what you asked for.
btw, so nice your new avatar !
- Del-Instance_KLT.tvpx
- (86 KiB) Downloaded 839 times
Re: Animator Panel
Hi Ray,
How did you ever decipher the request; I couldn't figure it out! But I certainly appreciate the button too and thank you both for it.
- toonsisters
Re: Animator Panel
hi zigotto,
thanks for your immediate solution.
I have tried it out. It does delete the instance without changing the global timing.
But it does also recompute the level.
Is there a chance to avoid this?
Shes always complainig. I thought that matches with a forum.
The cleaning woman ist the secret hero of my new animation short "sauna tango".btw, so nice your new avatar !
Re: Animator Panel
Hehehe, you're not so complaining, Vera ^^
I personaly tell you "Thanks a lot" =)toonsisters wrote:First I have to say, I like the 9.5 Version a lot!
Re: Animator Panel
teaching to young studients help a lot to become a good decipherer ...Paul Fierlinger wrote:Hi Ray,
oups... I thought the "recompute" george commandtoonsisters wrote:... I have tried it out. It does delete the instance without changing the global timing.
worked only on the selection, not processing the whole layer ...
btw, I don't see when to avoid this could be advantageous, ... anyway here's a new version
that you can try, tell me if it works as you want.
- Del-Instance_Vera.tvpx
- (86.5 KiB) Downloaded 870 times
- toonsisters
Re: Animator Panel
Wonderfull!
Thank you so much.
Wenn working on the blank but timed level the new "Vera" version does not elemiate the timing of the blanks at the end.
Trying not to be cryptical.
Maybe its german gramma with english words that makes my requests scramble.
Thank you so much.
To seperate animation of body and arm for example, I copy and clear the level.btw, I don't see when to avoid this could be advantageous, ...
Re: Animator Panel
oh, I see now, good point.toonsisters wrote:When working on the blank but timed level the new "Vera" version does not elemiate the timing of the blanks at the end.
so use only the second version, and delete the first one which was doing too much, more than needed.
