Manuel's gallery : lab samples
Posted: 20 Jun 2006, 11:48
by Manuel
Some pictures made by adding frames generated with the Cube plugin, in TVPA.
Posted: 20 Jun 2006, 11:49
by Manuel
Idem.
by Manuel
Idem.
Posted: 20 Jun 2006, 11:57
by fabrice_
Really nice, especially the first one.
by TVPaint
Hi Manuel
maybe you can tell us more about the method you used to obtain that kind of pictures with that nice effect ?
Posted: 21 Jun 2006, 08:08
by Manuel
Here is a way to create such kind of pictures :
step 1 - create an animation
Use a high number of frames, 256, 512 or 1024 ( preferably a power of 2).
It works great with color trails over a black background color.
I used the "Cube" Plugin but you can use any animation tool. (great results with particles, slow motion)
Frames MUST be fully opaque.
step 2 - Adding the frames together
(A)First, decrease the color brightness (to 10%), this will avoid color values to overflow.
(B)Split the layer in two, justify them to left, they should match exactly.
Merge the layers in add mode by dropping the upper layer's icon over the lower's one. Check the "Erase source" box.
Repeat the (B) operation until you have one frame left.
If the colors start to "burn", repeat the (A) operation.
step 2 alternative 1
Stretch the layer to 20% of its original size.
Normalize the color.
Repeat until there is only one frame left.
step 2 alternative 2
If your frames are 480/360 pixels or less :
Save your frames as BMP 24 bits.
Use FradderLight tool (free demo, PC) to add them together.
Choose the % value and then load the files.
step 2 alternative 3
Use Fradder tool from TPP (commercial tool set licence for 70 euros).
The addition is made using floating point values for better results.
Note to moderator : you can erase this paragraph if it is too "commercial" or SPAM.
Posted: 21 Jun 2006, 09:16
by electro-box
I like second one
Posted: 12 Dec 2006, 19:47
by fabrice_
this link will maybe interest you Manuel :
http://imagesavant.com/
Posted: 15 Jan 2007, 17:34
by Manuel
News from the Lab :
I have uploaded some pictures in the gallery.
Here is a Gif-anim, a "3D"bee in mosaïc.
The mosaic effect was made with a plug-in.
Posted: 19 Jan 2007, 16:44
by Manuel
Here is a link to a 3mb MOV file.
It shows some wave effects made with an upcoming plug-in for TVPaint Animation.
Sorry for the bad pictures quality, I was focused on the effect.
http://www.tpp.le-site-web.com/Gallery/vg.mov
Posted: 21 Jan 2007, 17:07
by donbartolo
really nice that wave-effect on the flag. ^^
Posted: 22 Jan 2007, 11:03
by Manuel
Strange color distortion appear if you apply a wave effect to a single channel only(RVB).
Here is such an animation. divx avi 700kb
Animation
