Strange "Multiply" mode behaviour
The left part of the attached image shows a shadow layer set to "multiply" and 75% opacity in TVP. The right part shows the same file with the same layer settings in Photoshop. Clearly there's a difference ...
TVP behaves strangely with this layer mode, sometimes I see the same effect in preview, sometimes not. The green result is the exported render, not a screenshot. It does not happen with black content in that layer, or when set to 100% opacity.
Anybody else experiencing this?
Re: Strange "Multiply" mode behaviour
i do have problems merging layers with different blendmodes.
doing that, i never get what i see, which i think is wrong.
i had not yet noticed this particular problem.
whats the RGB value of the color you use for the shadow?
Have a look at the file yourself, this is from the original file.
balkon3aCrop.tvpp.zip
(592.1 KiB) Downloaded 691 times
yeap, definitively something wrong, sometimes it displays false colors, as in your screeshot, but sometimes not ...
I can't see any reason for this ... :?
note : if I hide your "schatten" layer, and add it to the BG via the Color/Image Source fx,
then set it to Multiply mode and 75% of opacity, the preview is OK.
Hervé
Post by Hervé »
OK, it's a bug ( only on Mac PowerPC or when SSE functions are disabled ).
It will be fixed in the next update.
Hervé ADAM, TVPaint Team
Favourite developer team ever.
