soft pencil
malcooning
soft pencil
Post by malcooning »
here's a nice brush, mimicking a soft, flat pencil.
set as follows:
Size - pressue - 50% (for project sized HD 720)
Jitter - (None) - 11.00%
Opacity - Pressure - 36.00%
Angle - direction - -110 degrees
Step - 10.00%
Tick 'Subpixel'
Anim 'Random'
you can get a different pencil if you set:
Angle - -20 Degrees
Step - 50 %
Enjoy!
Soft pencil.zip
(18.04 KiB) Downloaded 470 times
TVPaint
Post by TVPaint »
have to try it...
Thank you very much for sharing !!
edit : i added 2 pictures made with your brush in order to have a sneak preview :)
malcooning
you should try to apply all the factors, especially the angle (-110 and -20), and step!
the preview below uses only this brush, with 2 different setups.
Soft pencil preview.jpg (63.53 KiB) Viewed 4336 times
fabrice_
Post by fabrice_ »
really nice rendering :o , well done !!
fanany
Post by fanany »
malcooning wrote:you should try to apply all the factors, especially the angle (-110 and -20), and step!
cool!...
did you use any paper texture?
(it seems not).
thanks malcooning.
its a nice one!
i found that
jitter set to inverted pressure "-P"
can get nice results with many custombrushes
alternative settings
malcooning
Fanany,
No I didn't use any paper texture. It's the scanned pencil that gives the grainyness. I must say, I'm only applying what I learned from those who persist to innovate ;)
Tantalus,
good point. I never thought of that. A good balance between size pressure and jitter inverted pressure can lead to very impressive brush strokes. I Must
play some with that!
Cheers.
