Hi all you folks.
I just wanted to share with you this brush I created to do my roughing. No rocket-science, just took an existing brush and fiddled with the settings. The advantage is that you can sketch with very broad and light strokes for seareching the line, and the more sure you are of your line the more pressure you give, causing the brush to narrow down and get darker. This combination makes it easy to do the whole roughing stage without having to switch brushes.
Enjoy!
lovely sketchbrush for roughing animations
- sketchbrush example.jpg (42.12 KiB) Viewed 2787 times
Re: lovely sketchbrush for roughing animations
Nice brush, you did a good job =)
i am not getting the results as in the image.
I liked the sketch and i'm always interested in new brushes but when i drag and dropped the tvpx i got a custompanel called "MY TVPX" which only contained a penbrush with a size set to Pressure 0.1 ???
BTW "My TVPX" is not a very good name for a toolpanel that you share, better give it a unique name like "Hilere-Sketch-Tool" or something along those lines.
Sorry, I made some stupid error exporting the brush, and did not check my work...unforgivable! Hope this time I did it right.
I've modified it to have another name than "My TVPx" =)
Very nice one for rough animation. Thanks!
- CartoonMonkey
Great tool! Thank you!
